How to use Linker from command line(error: mwldmcf.exe: No library file found matching  mwldmcf.exe: 'libC_TRK_4i_CF_SZ_MSL.a{.dylib|.a}' or 'C_TRK_4i_CF_SZ_MSL.a' )
1,147 次查看
saineelam
Hi everyone,
I am using code warrior v7.2,trying to use linker from command line the message it gives is
any document for command line usage will be helpful.
IDE: freescale warrior 7.2
Target :8252
Thanks and regards
Sai
888 次查看
CrasyCat
Specialist III
Hello
Please check {Install}\Help\PDF\ColdFire_Build_Tools_Reference.pdf. There is a section called Using Build Tools on the Command Line in there.
This should provide you with information on required environment variables and how to invoke the tools from command line
CrasyCat
