How to simulate to read analog input (DC voltage) using Freescale CodeWarrior Ver-6.3 IDE. I have used CW IDE to simulate output ports using Visualization Tool "LED Instrument". I would like to know, how we can simulate to read switch inputs through I/O p
2,340 次查看
srinivasubatchu
I am using Freescale Codewarrior IDE ver6.3 to simulate I/O ports as output and to see the same in Simulator using Visualization Tool - LED Instrument. I could able to do the same for outputs with out any problem and now I want to simulate to read the switch inputs through input ports and to simulate to read analog voltage (DC voltage) through A/D converter.
Can you please let me know the procedure to read the switch inputs, analog signals etc in CodeWarrior IDE debug window.  I do not have Frescale target board and trying with Codewarrior IDE Simulator.
My e-mail id:  [email protected]
1,970 次查看
ZhangJennie
Hi Srinivasb,
Please refer attached demo project and video for how to uses led component.
Jennie Zhang
