How to remove plugin form CW10.2
1,174 次查看
ignisuti
I added a plug-in and now wish I hadn't. How can I remove it?
989 次查看
CrasyCat
Specialist III
Hello
  If you install the plug ins using the menu Help > Install New Software you can try the following:
      - Select Help > About CodeWarrior Development Studio
      - Click on Installation Details.
      - Select the Plug in you want to remove and click Uninstall
CrasyCat
989 次查看
ignisuti
Thanks for the info, but I don't see the SlickEdit plug-in at that location.
989 次查看
CrasyCat
Specialist III
Hello
  Then the plug in has been installed in a non conventional way.
   I would recommend you to contact the creator of the plug in and ask him for un-installation instructions,
CrasyCat
