How to create overlays in .lcf?
1,564 次查看
Susmit
       I am using CW 4.6.2.626. I am trying to create overlays in the .lcf file. Any example .lcf will be of great help.
Regards -
Susmit
标签 (1)
2 回复数
1,150 次查看
CrasyCat
Specialist III
Hello
- Which CPU are you targeting (HC08, HC12, Coldfire, ..)
- Which version of CodeWarrior are you using?
  To retrieve that info:
    - Start CodeWarrior
    - Select Help -> About Freescale CodeWarrior
    - Click on "Install Products"
    - CodeWarrior version used is displayed on top in the Installed Products dialog.
CrasyCat
1,150 次查看
Susmit
     I am using Metrowerks Codewarrior 4.2.6.862. I am targeting mips.
Regards-
Susmit
