How to Disable printf in Code Warrior Libraries
SubbuGE
Hi, I am using code warrior 8.2.3. I want to disable printf feature in libraries.
I also uncheck the disable deadstripping option in Code warrior target settings.
So please suggest a good solution to disable printf feature in libraries. Because i am facing data overflow segment is coming.
CrasyCat
Specialist III
Hello
- Which CPU are you targeting (HC08, HC12, Coldfire, ..)
- Which version of CodeWarrior are you using?
  To retrieve that info:
     - Start CodeWarrior
    - Select Help -> About Freescale CodeWarrior
    - Click on "Install Products"
    - CodeWarrior version used is displayed on top in the Installed Products dialog.
CrasyCat
CrasyCat
Specialist III
This discussion was moved to a better location.
