Hello
Apparently Eclipse did keep some internal references to the deleted files. Can you try the following:
- Click right on the project name in the CodeWarrior Projects View
- in the drop Down Menu select Refresh.
- Click right on the project name in the CodeWarrior Projects View again
- In the drop down menu select Index > Rebuild.
Once indexing is over, perform your search again.
CrasyCat
