How can I put my code to RAM segment?
3,693 次查看
pvi
I try do it with :
#pragma CODE_SEG RAM
my function.......
#pragma CODE_SEG DEFAULT
but it don't work - CodeWarrior put my code to ROM.
1,669 次查看
CrasyCat
Specialist III
Hello
- Which CPU are you targeting (HC08, HC12, Coldfire, ..)
- Which version of CodeWarrior are you using?
To retrieve that info:
- Start CodeWarrior
- Select Help -> About Freescale CodeWarrior
- Click on "Install Products"
- CodeWarrior version used is displayed on top in the Installed Products dialog.
For CodeWarrior for HC12 or CodeWarrior for HC12:
  - take a look at TN235 for information on how to run portion of application from stack.
  - take a look at TN228 for information on how to run portion of application from RAM.
You can download the 8/16 bit Technical Notes from following link:
Then download 816TNSP.
I hope this helps.
CrasyCat
1,669 次查看
pvi
I use CodeWarrior V5.7.0, HCS08
1,669 次查看
CrasyCat
Specialist III
Then look at the Technical notes I specify in my earlier post
CrasyCat
