Getting reset problem while connecting MSBA8100ADS
1,988 次查看
puru
I am working on MSBA8100ADS. While running stationary project provided in code warrior version 3.2, I am getting reset target fail message. This board is having two jtag connector p1 and p2. I am confused where should I connect usb tap while running this stationary project and what should be code warrior setting in this case.
If some one having any idea then please do the needful asap.
Purushottam
1,025 次查看
J2MEJediMaster
Specialist I
Check the User's Guide document that normally comes with the board. It should tell you what jumpers need to be set, and which connectors to use.
---Tom
