Getting FlexLm to recognize the USB Dongle
4,314 次查看
v_dave
Hello All,
I have downloaded MW_FLEXlm_V1_4.exe from freescale.com and ran the installation.  After I install FlexLm I plug n the USB Dongle and I am prompted to install the drivers.  I select automaticlly find the correct drivers and the Wizard comes bck with unable to find the drivers.
The little 1 sheet of instructions that came with the dongle tell me that when FlexLM install starts to make sure I select install Dongle Drivers.  I never see this option during installation.
Is there a different version of the FlexLm I need to install?
Dave
标签 (1)
2 回复数
1,307 次查看
CrasyCat
Specialist III
Hello
As far as I can tell, you need to install "Standard Driver Installer"  from following URL:
Then check whether your dangle is recognized
If dangle is not recognized, please install "Driver Update" as well.
CrasyCat
1,307 次查看
v_dave
Thanks.
The Driver update fixed the problem.
Dave
