FreeMaster recorder with MC56F8006DEMO
已解决
跳至解决方案
4,255 次查看
Gibson
I'm trying to use the FreeMaster's recorder with the MC56F8006DEMO. As I tried to activate a record window in FreeMaster, I'm getting error message : the hardware recorder could not be initialized (Invalid size specified). I changed the Data buffer size, Recorder buffer length and now I have a size incompatible with bus width error.
Is there a guide to properly size the "Data buffer size", "Recorder buffer length", "Command buffer length" in the initialization of the PC_Master Bean?
Gibson
标签 (1)
标记 (1)
1 解答
2,527 次查看
Gibson
Hi Tom,
I already check most of the thread for Freemaster. No much on the freemaster's recorder.
Anyway, by trial and error, I finally find some working settings.
In my case with the MC56F8006DEMO:
- Data buffer size : 40
- Recorder buffer length : 80
- Command buffer length : 4
Gibson
在原帖中查看解决方案
3 回复数
2,527 次查看
believe
I haveing use Freemaster do BLDC project, it can do  properly, but I can not find  "Data buffer size", "Recorder buffer length", "Command buffer length" , where they are?
Are you Chinese? I am doing sensorless BLDC with MC56F8006,can we communication with 8006?
My mobile phone is :+86 13705541506,my QQ is 356119619,can we study with each other?
2,527 次查看
J2MEJediMaster
Specialist I
You might try the using the search function to search the forums. I entered "Freemaster" and got a few hits. This https://community.freescale.com/message/45605#45605 looks the most promising. Hope it helps.
---Tom
2,528 次查看
Gibson
Hi Tom,
Gibson
