Flashing a S-Record file using USB TAP debugger (ONCE)
1,750 次查看
Kanthi
Can we flash a S-Record file on to the controller board using a USB TAP Debugger?
标记 (1)
695 次查看
J2MEJediMaster
Specialist I
Check out the Flash Programmer users guide.doc file located in {CodeWarrior Installation}\56800x Support\56800E flash programmer\docs. It mentions that you can use both ELF and S-records with the 56800E Flash Programmer application.
