File transport Reader failed
1,271件の閲覧回数
eskalaiyarasan
HI,
   I am new to code warrior. I had installed code warrior 10.1 eclipse IDE and MQX RTOS.  I not able to build new project.
I am getting error as given below
=#error You need to install Code Warrior V10.1 latest compiler patch. The code is unstable if patch is not used.
>preprocessor #error directive
Errors caused tool to abort.
When I tried to do following:
   CodeWarrior --> Help --> Install New Software
   In Search TextBox, I had selected "Code warrior Microcontroller tool chain update"
   I chosen Codewarrior 10.1 update and Microcontroller.
I am getting error:
  File Transport Reader Failed
How to resolve this....
--Kalaiyarasan
1,150件の閲覧回数
CrasyCat
Specialist III
Hello
There is an Update Procedure document that explains how to install the Compiler Update (http://cache.freescale.com/files/soft_dev_tools/doc/support_info/CW_MCU_v10.1_Update_Procedure.pdf?f...) in offline or online mode.
Try using off-line mode.
CrasyCat
