Error message C44222
5,311 次查看
roberthiebert
Senior Contributor I
CW IDE V5.9.0 Build 5294. I have a project using an MC9S12C64 with existing code that I would like to modify, but I am having no success getting it to compile. When I try Make, I get this error message:
ERROR: C4422: ' Missing
flash.asm line 51
and the warning message:
Warning: C4450: Multi character constant
flash.asm line 51
The error points to line 51 in the flash.asm file, but it is a line of information commented out with ;* at the beginning of the line.
Can anyone help me with this?
Also, does CW generate an object file and if so where can I find it?
Robert
4,911 次查看
roberthiebert
I found the non connection problem. I am working with a new Win 11 machine and didn't install the USBDM drivers. After installing them I was able to connect to the controller. I am going to give up on the "C" program and try to translate it to assembler.
10 回复数
5,278 次查看
Hello @roberthiebert
Could you please share your project, I help you check on my side. If your project cannot be public. You can also create a private ticket. https://support.nxp.com/s/?language=en_US
Alice
5,272 次查看
roberthiebert
Hi Alice,
Thanks for your response. I don't see any reason why it can't be public so how do I share it?
I am quite new to C programming so I may be missing something obvious.
Robert
5,260 次查看
Please attach it through "browse" button as below:
Alice
5,237 次查看
roberthiebert
Is this what you need?
Robert
5,197 次查看
I open your project and compile it on my side, it seems there is no error. Just some Warnings.
Alice
5,129 次查看
roberthiebert
Thanks Alice. I apologize for my late reply but I was away from my computer for a couple of weeks.
There are a lot of unused files in the zip file I sent you, and I need to use the BDM. I tried to create a new project with just the files that I need to keep things a simple as possible. When I did this and tried to compile, it came up with several errors that I don't know how to deal with. I'm attaching the zip file.
Robert
5,092 次查看
I recommend you a simple method. Use a simple demo for example hello world. Confirm there is no issue hen build. Then copy & paste your application files and code into the project.
Alice
4,925 次查看
roberthiebert
Up until this point I was just writing code but I didn't have a processor to test it on. Since then I have built a test module with the MC9S12C64 processor. I have a Freescale USBDM that works well on another project with a MC9S12XEP100.
I started a new simple project for the MC9S12C64 in absolute assembly and had Code Warrior do create the initial .asm file. When I connect the USBDM to the processor the power indicator on the USBDM lights up. When I connect the USB cable to the computer the USB indicator lights up, but when I try to load the program I get the following message:
"The debugger can not connect to the P&E BDC interface or targeted hardware board."
I have no idea where to even start to troubleshoot this. Any suggestions would be appreciated
Robert
4,912 次查看
roberthiebert
5,127 次查看
roberthiebert
%3CLINGO-SUB%20id%3D%22lingo-sub-1939754%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20C44222%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1939754%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECW%20IDE%20V5.9.0%20%E7%89%88%E6%9C%AC%205294%E3%80%82%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E4%BD%BF%E7%94%A8%20MC9S12C64%20%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%85%B6%E4%B8%AD%E6%9C%89%E6%88%91%E6%83%B3%E4%BF%AE%E6%94%B9%E7%9A%84%E7%8E%B0%E6%9C%89%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%E6%88%91%E6%97%A0%E6%B3%95%E6%88%90%E5%8A%9F%E7%BC%96%E8%AF%91%E5%AE%83%E3%80%82%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%20Make%20%E6%97%B6%EF%BC%8C%E6%94%B6%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9AC4422%EF%BC%9A'%E7%BC%BA%E5%A4%B1%3C%2FP%3E%3CP%3Eflash.asm%20%E7%AC%AC%2051%20%E8%A1%8C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A5%E5%8F%8A%E8%AD%A6%E5%91%8A%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9AC4450%EF%BC%9A%E5%A4%9A%E5%AD%97%E7%AC%A6%E5%B8%B8%E9%87%8F%3C%2FP%3E%3CP%3Eflash.asm%20%E7%AC%AC%2051%20%E8%A1%8C%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%E6%8C%87%E5%90%91flash.asm%E6%96%87%E4%BB%B6%E7%9A%84%E7%AC%AC51%E8%A1%8C%EF%BC%8C%E4%BD%86%E6%98%AF%E8%BF%99%E6%98%AF%E4%B8%80%E8%A1%8C%E5%9C%A8%E8%A1%8C%E9%A6%96%E7%94%A8%3B*%E6%B3%A8%E9%87%8A%E6%8E%89%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E5%B8%AE%E6%88%91%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8CCW%20%E6%98%AF%E5%90%A6%E4%BC%9A%E7%94%9F%E6%88%90%E7%9B%AE%E6%A0%87%E6%96%87%E4%BB%B6%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E5%AE%83%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ERobert%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20C44222%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E4%BA%86%E4%B8%8D%E8%BF%9E%E6%8E%A5%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%B8%80%E5%8F%B0%E6%96%B0%E7%9A%84%20Win%2011%20%E6%9C%BA%E5%99%A8%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E5%AE%89%E8%A3%85%20USBDM%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E5%AE%89%E8%A3%85%E5%90%8E%E6%88%91%E5%B0%B1%E8%83%BD%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BA%86%E3%80%82%E6%88%91%E6%89%93%E7%AE%97%E6%94%BE%E5%BC%83%E2%80%9CC%E2%80%9D%E7%A8%8B%E5%BA%8F%E5%B9%B6%E5%B0%9D%E8%AF%95%E5%B0%86%E5%85%B6%E7%BF%BB%E8%AF%91%E6%88%90%E6%B1%87%E7%BC%96%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1970720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20C44222%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1970720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%EF%BC%8C%E6%88%91%E5%8F%AA%E6%98%AF%E5%9C%A8%E7%BC%96%E5%86%99%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E5%A4%84%E7%90%86%E5%99%A8%E6%9D%A5%E6%B5%8B%E8%AF%95%E5%AE%83%E3%80%82%E4%BB%8E%E9%82%A3%E6%97%B6%E8%B5%B7%EF%BC%8C%E6%88%91%E7%94%A8%20MC9S12C64%20%E5%A4%84%E7%90%86%E5%99%A8%E6%9E%84%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E6%B5%8B%E8%AF%95%E6%A8%A1%E5%9D%97%E3%80%82%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20USBDM%EF%BC%8C%E5%AE%83%E4%B8%8E%20MC9S12XEP100%20%E4%B8%80%E8%B5%B7%E5%9C%A8%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%8A%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%BB%9D%E5%AF%B9%E6%B1%87%E7%BC%96%E8%AF%AD%E8%A8%80%E4%B8%BA%20MC9S12C64%20%E5%90%AF%E5%8A%A8%E4%BA%86%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E7%AE%80%E5%8D%95%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%B9%B6%E8%AE%A9%20Code%20Warrior%20%E5%88%9B%E5%BB%BA%E5%88%9D%E5%A7%8B%20.asm%E6%96%87%E4%BB%B6%E3%80%82%E5%BD%93%E6%88%91%E5%B0%86%20USBDM%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%A4%84%E7%90%86%E5%99%A8%E6%97%B6%EF%BC%8CUSBDM%20%E4%B8%8A%E7%9A%84%E7%94%B5%E6%BA%90%E6%8C%87%E7%A4%BA%E7%81%AF%E4%BA%AE%E8%B5%B7%E3%80%82%E5%BD%93%E6%88%91%E5%B0%86%20USB%20%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%AE%A1%E7%AE%97%E6%9C%BA%E6%97%B6%EF%BC%8CUSB%20%E6%8C%87%E7%A4%BA%E7%81%AF%E4%BA%AE%E8%B5%B7%EF%BC%8C%E4%BD%86%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%BB%A5%E4%B8%8B%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E2%80%9C%E8%B0%83%E8%AF%95%E5%99%A8%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0P%26amp%3BE%20BDC%E6%8E%A5%E5%8F%A3%E6%88%96%E7%9B%AE%E6%A0%87%E7%A1%AC%E4%BB%B6%E6%9D%BF%E3%80%82%E2%80%9D%3C%2FP%3E%3CP%3E%E6%88%91%E7%94%9A%E8%87%B3%E4%B8%8D%E7%9F%A5%E9%81%93%E4%BB%8E%E5%93%AA%E9%87%8C%E5%BC%80%E5%A7%8B%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E9%83%BD%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ERobert%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1959379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20C44222%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1959379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F5684%22%20target%3D%22_blank%22%3E%40roberthiebert%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%90%91%E4%BD%A0%E6%8E%A8%E8%8D%90%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E6%BC%94%E7%A4%BA%E4%BE%8B%E5%A6%82%20hello%20world%E3%80%82%E7%A1%AE%E8%AE%A4%E6%9E%84%E5%BB%BA%E6%97%B6%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%E7%84%B6%E5%90%8E%E5%B0%86%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%96%87%E4%BB%B6%E5%92%8C%E4%BB%A3%E7%A0%81%E5%A4%8D%E5%88%B6%E5%B9%B6%E7%B2%98%E8%B4%B4%E5%88%B0%E9%A1%B9%E7%9B%AE%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1959116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20C44222%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1959116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1959115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20C44222%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1959115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E7%88%B1%E4%B8%BD%E4%B8%9D%E3%80%82%E5%BE%88%E6%8A%B1%E6%AD%89%E6%88%91%E7%9A%84%E5%9B%9E%E5%A4%8D%E8%BF%99%E4%B9%88%E6%99%9A%EF%BC%8C%E4%BD%86%E6%98%AF%E6%88%91%E5%B7%B2%E7%BB%8F%E6%9C%89%E5%87%A0%E4%B8%AA%E6%98%9F%E6%9C%9F%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E7%94%B5%E8%84%91%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%91%E7%BB%99%E4%BD%A0%E7%9A%84%20zip%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%9C%89%E5%BE%88%E5%A4%9A%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20BDM%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E4%BB%85%E5%8C%85%E5%90%AB%E6%88%91%E9%9C%80%E8%A6%81%E7%9A%84%E6%96%87%E4%BB%B6%E7%9A%84%E6%96%B0%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BB%A5%E5%B0%BD%E5%8F%AF%E8%83%BD%E4%BF%9D%E6%8C%81%E7%AE%80%E5%8D%95%E3%80%82%E5%BD%93%E6%88%91%E8%BF%99%E6%A0%B7%E5%81%9A%E5%B9%B6%E5%B0%9D%E8%AF%95%E7%BC%96%E8%AF%91%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BA%86%E5%87%A0%E4%B8%AA%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%A4%84%E7%90%86%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E9%99%84%E5%8A%A0%20zip%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ERobert%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1948040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20C44222%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1948040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F5684%22%20target%3D%22_blank%22%3E%40roberthiebert%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%89%93%E5%BC%80%E4%BD%A0%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%B9%B6%E5%9C%A8%E6%88%91%E8%BF%99%E8%BE%B9%E7%BC%96%E8%AF%91%E5%AE%83%EF%BC%8C%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%E3%80%82%E5%8F%AA%E6%98%AF%E4%B8%80%E4%BA%9B%E8%AD%A6%E5%91%8A%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1725526329391.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1725526329391.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F297318i0E078FA1A0B38F7F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1725526329391.png%22%20alt%3D%22Alice_Yang_0-1725526329391.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1943680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20C44222%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1943680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%BD%A0%E9%9C%80%E8%A6%81%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ERobert%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1943358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20C44222%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1943358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F5684%22%20target%3D%22_blank%22%3E%40roberthiebert%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E2%80%9C%E6%B5%8F%E8%A7%88%E2%80%9D%E6%8C%89%E9%92%AE%E9%99%84%E5%8A%A0%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1724925661001.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1724925661001.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F296045iFE0AB4EEAF3F6B8E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1724925661001.png%22%20alt%3D%22Alice_Yang_0-1724925661001.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1942424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20C44222%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1942424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Alice%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E4%B8%BA%E4%BB%80%E4%B9%88%E5%AE%83%E4%B8%8D%E8%83%BD%E5%85%AC%E5%BC%80%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E5%88%86%E4%BA%AB%E5%AE%83%E5%91%A2%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%B9%20C%20%E7%BC%96%E7%A8%8B%E8%BF%98%E5%BE%88%E9%99%8C%E7%94%9F%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%8F%AF%E8%83%BD%E9%81%97%E6%BC%8F%E4%BA%86%E4%B8%80%E4%BA%9B%E6%98%8E%E6%98%BE%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ERobert%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1942150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20C44222%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1942150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F5684%22%20target%3D%22_blank%22%3E%40roberthiebert%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%91%E4%BC%9A%E5%B8%AE%E6%82%A8%E6%A3%80%E6%9F%A5%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%8D%E8%83%BD%E5%85%AC%E5%BC%80%E3%80%82%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E5%88%9B%E5%BB%BA%E7%A7%81%E4%BA%BA%E7%A5%A8%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fsupport.nxp.com%2Fs%2F%3Flanguage%3Den_US%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fsupport.nxp.com%2Fs%2F%3Flanguage%3Den_US%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E
