Drivers for MC9S08QE128 for 64 bits OS
aldomadrid
Hello!
Some years ago I bought a Demoque128 board with a MC9S08QE128 microcontroller (also the MCF51QE128 included).
I used it at the university, but now that I'm trying to use it in Windows 7 I cannot install the drivers.
When I run the installation software for the drivers it tells me: "cannot run an x86 build of this utility on x64 platform".
I already installed the CW_MCU_V6_3_SE.exe.
Can anyone help me to find the drivers or tell me what can can I do to run the microcontroller.
Thank you for your time!
Regards.
ZhangJennie
classic CW was not designed for 64bit win7,We have an3936 for how to install classic CW on 64bit win7
http://cache.freescale.com/files/soft_dev_tools/doc/app_note/AN3936.pdf
CW10.6 was designed for 64bit win7, it includes support for HCS08 device. I recommend you use CW10.6 instead:
CodeWarrior for Microcontrollers-Eclipse IDE|Freescale
does it answer your question?
Zhang Jun
ZhangJennie
Zhang Jun
aldomadrid
Thank you so much! Both methods worked perfectly.
Have a great day you too,
Aldo Madrid
