Does Stand alone Flash Programmer tools support 56F803?
JeffZ
Hi everybody
I just found a stand alone Flash Programmer from freescale web. I downloaded it and tryed to flash 56F803. But I can not find configuration file from the itself file list. It seems it only support 56F8000 parts. is that true?
another question about this tools is: Does it support Macraigor Wiggler (parallel port)? When I tryed my Macraigor Wiggler, I got some errors.
JeffZ
trytohelp
The Flash programmer tool (56800E Flash Programmer.exe and fflash.exe) is not running for Hawk 1.
We recommend you to use the flash_over_jtag.
We've another version: flash_over_jtag.
Please refer in your installation under:
\ProcessorExpert\Tools\applications\flash_over_jtag\flash_jtag_loader_80x_82x
The tool is flash_over_jtag.exe. This is not a GUI.
Have a look to the doc: Flash_over_JTAG.pdf.
This tool doesn't support the USBTap interface.
You need to use a parallel cable plug on host and board.
It should work with the Macraigor Wiggler too.
Pascal
