Debugging using CW for Microcontroller 10.2
1,574件の閲覧回数
Mohsin455
Hi All,
I am using K60N512 for my project. I am developing the code using command line options. As I am new to to CW and I am using CW for Microcontroller 10.2. I want to know how could I debug the code when I do a build using command line.
In MPLAB and VisualDSP++,  the IDE allows me to import/load the image file so that I can debug it i.e. put breakpoints, single step etc.
Can anyone please let me know how we could do similar thing using CW for Microcontroller 10.2 ?
Mohsin
1,291件の閲覧回数
Teo
You can create a CW project using executable importer and debug from there.
i.e.  In the projects view select "Import->CodeWarrior->MCU Executable Importer". On next page name the project to debug the executable, then browse for the executable to debug. You will be asked for the CPU/board used. Select one that you are targetting.
After project has been created you can debug it as all other usual projects.
Teo
