Data visualization
Data visualization
2,640 次查看
knarf
I'm using Codewarrior for DSC56800E 8.3; I'd like to monitor some variables while debugging on target board ( I use usb tap connection ). I have tried configuring "Data visualization" after launching a debug session. I can select any global variable, the graph window appears but the variable I selected is not traced on it. The same happens if I select a memory location instead of a global var. Is there any other setting that I have to configure ?
I'm also not able to pause the debug session untill the graph window is open: I have to close it and then I can pause the debug. Is that correct?
Many thanks
knarf
标签 (1)
标记 (1)
1 回复
2,272 次查看
admin
Specialist II
As far as I understand data vizualization window refreshed while you trace application (i.e. step tracing, brakepoint tracing).
Deug window and graph window are independent - see attachment. Switch between them while debugging.
