DSP56F805: Assigning a fixed address to a global variable.
2,265 次查看
DouglasHolub
I'm using CodeWarrior 4.2 for the DSP56F805.  I would like one particular variable in my code, bPacketS, to always be assigned address 0x679 during the linking process. How do I tell the linker to do that? Is there a directive I could use in the source file?
Doug Holub
Irving, Texas
Message Edited by CrasyCat on 2007-04-13 01:30 PM
标记 (1)
987 次查看
Lundin
Senior Contributor IV
There is the '@' operator but it isn't ANSI C.
I would suggest using the .prm file for this.
