DSP segment overflows.
3,615 次查看
campcerkit
 I'm beginner for DSP. I'm not clear about  warning from program .
Message Edited by J2MEJediMaster on 2009-01-23 11:22 AM
标记 (1)
1,984 次查看
campcerkit
"Segment overflow: .p_Code at line 103
Load_address of segment .p_flash_ROM_data is 0x00003da0 (located in .p_Code segment).         Reserved size of segment .p_Code is 0x00003f48 -- Overflow 0x00000028"
What is wrong?
Message Edited by campcerkit on 2009-01-23 05:00 PM
1,984 次查看
jeypi
The Flash memory doesn't have enough space to execute you program. Try to comment some part of your code and see what happens.
João Paulo.
1,984 次查看
J2MEJediMaster
Specialist I
What version of the CodeWarrior tools are you using? What is the target board and processor? Are you trying to run a sample program that came with the CodeWarrior installation, or one of your own?
---Tom
