CodeWarrior 10.2 Syntax coloring
PhilFree
Syntax coloring is not working for assembly sources (*.asm) , the keys, variables, and others have the same color, but not the right defined in the Assembly syntax coloring menu. Only the label use the right color. Same for assembly code in C source. System run under XP SP3.
CrasyCat
Specialist III
Hello
 Which CPU are you targeting (HC08, HC12, Coldfire, ..)
CrasyCat
PhilFree
I have targeting HCS08, ColdFire V1 (__asm key) , using bareboard Project,  idem with imported projects (HCS08) from CW6.3. File extention is the same as CW6.3.
The exported projects from CW6.3 have the rigth ASM Syntax coloring but the ASM syntax coloring is wrong in CW10.2 (not working)
In fact, the menu Preferences/C-C++/Editor/Syntax coloring/Assembly/Directive is not working.
In CW6.3, the variables in ASM source have the same color as in C source, not in CW10.2, In asm sources, only labels and  comments are colored, all the keys, var, operators (#$..), etc have the same color.
PhilFree
