Calling a pre-build script
1,412件の閲覧回数
DanielLundborg
Hello!
I am using Metroworks CodeWarrior 5.6 IDE for DSP56800E cpu. I want to start creating unit tests for my software and I want to build some of it for the Windows PC and use Check (or some other testing framework) to test the code.
I cannot find anything about pre-build commands to invoke the IDE to run my commands. Is there any possibility to do so in CW 5.6?
タグ(1)
1,119件の閲覧回数
J2MEJediMaster
Specialist I
Check out Chapter 3, "Using Build Tools on the Command Line", in the 56800x Build Tools Reference manual. This manual is an Acrobat file named 56800x_Build_Tools_Reference.pdf, and the file should be located in the Help folder of your CodeWarrior installation folder.
---Tom
