CW8 ProcExp - 56F8357 - problem PWM control
5,315 次查看
howdeterminepwm
HI,
I cant ON PWMA5 in Demo Board. I can enable all PWM's A0-A4 except A5. I have using Processor Expert, and Code Warrior not returns error. Other problem, enabling one PWM, all PMW's is ON, example:
ACTION: Enable PMWA0
RESULT: Enable PWMA0, PWMA1, PWMA2, PWMA3, PWMA4 (except five)
ACTION: Press IRQB for disable PWMA0
RESULT: Disabled PWMA0, and no change for others
How enable PWM5 and no enable all?
Message Edited by Alban on 2007-09-20 09:29 AM
标记 (1)
6 回复数
2,537 次查看
Alban
Senior Contributor II
Have you read this post, by any chance ?
[IMPORTANT] When Asking about CODEWARRIOR !!!
Alban.
2,537 次查看
howdeterminepwm
Sorry, where edit topic??
Thank you!
2,537 次查看
J2MEJediMaster
Specialist I
Every time you post, you need to supply the CPU type and CodeWarrior version in the subject header. You're talking details about a PWM, but since many Freeacale CPUs have these, no one has an idea what part you're talking about. I've seen you post before with this information. I'm assuming that you're still using DSP56800/code warrior 8 with a 8357? Just keep in mind not everyone is going to read every post in the forum, and so you have to provide the information each time.
---Tom
2,537 次查看
howdeterminepwm
Sorry, my cpu is 56f8357 and code warrior is version 8, using Processor Expert (PE). You're correct Tom.
Message Edited by how determine pwm frequency on 2007-09-19 03:49 PM
2,537 次查看
trytohelp
Can I suggest you to log this question in our CRM system ?
The problem must be handle by our support team and may be our Third Party Unis.
Please use Freescale on line support web page.
  - Go to following URL: http://www.freescale.com/TechSupport
  - Click on Submit a Service Request. You will come to a login page.
  - You can submit your request through the web from there.
There is a patch for the DSC8.0 (must be installed in first) DSC8.1.1
You can download it on our web site via the link:
 http://www.freescale.com/webapp/sps/site/overview.jsp?nodeId=01272600617882140B
Pascal Irrle
2,537 次查看
howdeterminepwm
Service Request, It's Made, thank yoou!
Message Edited by how determine pwm frequency on 2007-09-20 03:55 PM
Message Edited by how determine pwm frequency on 2007-09-20 03:56 PM
