CW8/DemoBoard56F8357/ProcessorExpert - Mapping external device
1,641 次查看
howdeterminepwm
HI,
How i can mapping a external device connected to CS3? In User manual "If a device is mapped from 0x20000 to 0x27FFF..." [MC56F8300UM - Pag:115 - Session: 4.5.1.1 ] . If i used one bus of devices connected to CS3, i need of Address to access devices in separated. In External Memory i set the address in visual tab of codewarrior and used the address for access EM, all right. While in devices connected i dont known mapper the devices, set address! Is in file IO_MAP.H ? Or in file CPU.c? How i made it? Thank you!
标记 (1)
585 次查看
trytohelp
We're very sorry for the delay.
Can I suggest you to log your request to the Freescale CRM system.
Please use Freescale on line support web page.
  - Go to following URL: http://www.freescale.com/TechSupport
  - Click on Submit a Service Request. You will come to a login page.
  - You can submit your request through the web from there.
Pascal
