CW 9.2 For Mobile GT Debugger Documentation
Tim562
Senior Contributor I
     Does anyone know where I might find documentation for the Debugger in CW 9.2? I need to learn a bit more about the twrmpc5125.cfg and twrmpc5125.mem files used in projects for the TWR-MPC-5125. Thanks!
~Tim
J2MEJediMaster
Specialist I
Look for the Help folder, which should be located in the CodeWarrior installation folder. This folder has all of the relevant documentation. You'll want to look in the Targeting_PA_Processors.pdf file for information on using the debugger.
---Tom
J2MEJediMaster
Specialist I
---Tom
Tim562
Hi Tom,
     I've found a file called "Targeting mobileGT Processors.pdf" in the folder you mention that looks like it has specific info on the debugger and the "Target Initalization" and "Memory Configuration" files. That seems to be just what I was looking for, thank you for your reply!
~Tim
