CW 9.2 For Mobile GT Debugger Documentation
1,897件の閲覧回数
Tim562
Senior Contributor I
     Does anyone know where I might find documentation for the Debugger in CW 9.2? I need to learn a bit more about the twrmpc5125.cfg and twrmpc5125.mem files used in projects for the TWR-MPC-5125. Thanks!
~Tim
1,653件の閲覧回数
J2MEJediMaster
Specialist I
Look for the Help folder, which should be located in the CodeWarrior installation folder. This folder has all of the relevant documentation. You'll want to look in the Targeting_PA_Processors.pdf file for information on using the debugger.
---Tom
1,654件の閲覧回数
J2MEJediMaster
Specialist I
---Tom
1,653件の閲覧回数
Tim562
Hi Tom,
     I've found a file called "Targeting mobileGT Processors.pdf" in the folder you mention that looks like it has specific info on the debugger and the "Target Initalization" and "Memory Configuration" files. That seems to be just what I was looking for, thank you for your reply!
~Tim
