CW 10.1 IDE language change
ソリューションへジャンプ
2,462件の閲覧回数
DerekTsou
My OS is WIN 7 x64 Chinese version, after install CW10.1, the IDE menu is mixed with some Chinese and English words.
I need to know the way to switch language to English purely.
Please help me.
The snapshot is as attached.
2,067件の閲覧回数
CrasyCat
Specialist III
Hello
As the Chinese systems have their locale set to Chinese, Code Warrior will comply and start  with some of the menus in Chinese.
The easiest solution to stay with English is to edit cwide.ini and add before –vmargs the following option:
-nl
en_US
CrasyCat
3 返答(返信)
2,068件の閲覧回数
CrasyCat
Specialist III
Hello
-nl
en_US
CrasyCat
2,067件の閲覧回数
karenzhang
CrasyCat wrote:
Hello
-nl
en_US
CrasyCat
I modified it according to your method, but it still have some Chinese.
Could you kindly please help me how to modify it?
Thank you very much.
2,067件の閲覧回数
DerekTsou
It works.
Thank you.
