CrasyCat wrote:
Hello
As the Chinese systems have their locale set to Chinese, Code Warrior will comply and start with some of the menus in Chinese.
The easiest solution to stay with English is to edit cwide.ini and add before –vmargs the following option:
-nl
en_US
CrasyCat
I modified it according to your method, but it still have some Chinese.
Could you kindly please help me how to modify it?
Thank you very much.
