Application code size
jesortsan
How can I know the complete code size of my application once I've built the project? I mean the total space that the program will take up in the microcontroller memory.
Lundin
Senior Contributor IV
Check at the bottom of the .map file generated by the linker.
jesortsan
OK,
I suppose the code size is which appears in the last line of the .map file:
"Total size of all blocks to be downloaded: 563"
563 bytes in this case, isn't it?
Lundin
Yep. And that should be the size of the nvm, since it doesn't count RAM.
