Application code size
3,820 次查看
jesortsan
How can I know the complete code size of my application once I've built the project? I mean the total space that the program will take up in the microcontroller memory.
1,634 次查看
Lundin
Senior Contributor IV
Check at the bottom of the .map file generated by the linker.
1,634 次查看
jesortsan
OK,
I suppose the code size is which appears in the last line of the .map file:
"Total size of all blocks to be downloaded: 563"
563 bytes in this case, isn't it?
1,634 次查看
Lundin
Yep. And that should be the size of the nvm, since it doesn't count RAM.
