56F8013 - Using C-declared variables in Assembly
2,655 次查看
EvanE
I would like to use Fast INT option of the 56F8013.  I understand that I can only write the ISR in Assembly.  I'm reading thru the documentation on how I can access the global variables that I have declared in my other C-files.  However, any heads-up on how to do this will be greatly appreciated.
Thanks!
Evan
Alban Edit: Please always include FSL Part Number in Message Subject line.
Message Edited by Alban on 2007-09-28 08:35 PM
标记 (1)
736 次查看
trytohelp
To resume you want to use C variables in assembly module.
I created a short example showing you how to do that.
Hope this will help.
Pascal
