HOW TO TEST AUTOSAR SW-C on NXP Microcontrollers
5,804 次查看
Daniel_Popa
To learn more about AUTOSAR SW-C, design, simulation and test on NXP HW please check this webinar
标记 (2)
2,574 次查看
emilyhayes
To test AUTOSAR SW-C on NXP microcontrollers:
  1. Set up the AUTOSAR environment with NXP-specific drivers.
  2. Compile the SW-C with the NXP toolchain (e.g., S32 Design Studio).
  3. Load the compiled code onto the NXP microcontroller using a debugger.
  4. Run the SW-C on the target and monitor functionality via trace tools or debuggers.
  5. Perform integration and system tests based on test cases.
  6. Analyze results using appropriate validation tools here.
4,570 次查看
Antonia
NXP offers a broad range of automotive software tools designed to help you to simplify and shorten the time required to build safe and secure vehicle networking, electric vehicle control and body and comfort applications, based on NXP microcontrollers and processors. USPayserv
From run-time and embedded software, real-time drivers, MATLAB/Simulink®-compatible toolboxes, ISO 26262-compatible safety software, to auto code generation support to AUTOSAR abstraction layers and operating systems (OS).
Thanks ,
Regards..
