zigbee 13213 sent massege to end device
1,952件の閲覧回数
moti
Im using 13213 EVK and tring to send data\maseges via uart to the coordinator and to the end device. im reading the 802154MSNAUG file - 2.1.7 Sending Data to the End Devices
but wuthout success
Do somebody know how to do it -please connect and advice.
Thank you,
1,203件の閲覧回数
Mads
Contributor V
Moti,
Try programming MyWirelessApp example 5a and b, or 6a and b into 2 boards.
The MyStarNetworkDemo also does the same thing.
Note if you are using low power mode, then try to disconnect the debugger.
Both application set does what you request.
BR,
Mads
