where are Community Files?
donw
How do I find the Community Files on this board?
- the '8 bit upload/download' link takes you to a text page about uploading,
which has  a link to 'community files', which says 'search not found'
Message Edited by donw on 2007-12-04 07:15 AM
peg
Senior Contributor IV
Hi Don,
The Community files area dissappeared some time ago.
If you use community files as a search term in the keyword box at the top right of the page, it will return links to the files that where in there. The links still work for the files.
Trying to be clever and shortening up the address to locate the actual repository only seems to lead to errors.
I didn't try to hard, maybe you can fiddle some more to locate them.
