there is no input and output interaction
939件の閲覧回数
Li9999
Why can the microcontroller program be debuged normally, but there is no input and output interaction?All processes are fine, but there is no response after the program is written in. And there are no values in the debugger.
900件の閲覧回数
Pablo_Ramos
Hi @Li9999,
Could you help me with the following information?
Which MCU and debugger are you using?
What version of CodeWarrior are you using?
Also, could you explain furthermore what is the expected behavior of the application?
