structure alignment on HCS08 uC
1,560 次查看
akasilov
Hi all!
I am using MC9S08DZ60 uC.
Are the structures always aligned to the 1 byte boundary?  Meaning the sizeof operator will always yield the size of data members, no padding bytes? Am I right?
Thank you for your help.
1,195 次查看
CrasyCat
Specialist III
Hello
I assume you are using CodeWarrior compiler for building. Am I right?
If this is the case, yes, there is no alignment constraint applying to ANSI C structure on HCS08 microcontrollers.
CrasyCat
