rtc interrupt every sec whilst continuing count
1,661 次查看
avditkohli
I wish to program the RTC of MC9S08pa16 to generate an interrupt every second where I compute some data whilst the RTC keeps counting. How do I do that?
Avdit
标记 (2)
1,315 次查看
ankur_kala
Hi Avdit,
From your description it seems that you need a periodic interrupt of 1 sec using RTC. For this you can use PE ->Init_RTC module, set the clock source as 1-KHz Low Power Oscillator, clock gate -> Enabled, Prescaler -> 100, Modulo Value -> 9. In the interrupts section, you must enable the interrupt and give the name of the ISR that you may define in your application.
Hope this answers your question.
Ankur
P.S. - If you see the answer helpful/correct, please mark appropriately.
