repeat VBS script
repeat VBS script
1,788件の閲覧回数
kurna
Hi, I use Freemaster for reading data from my 8-MCU. I am trying to make simple HTML page, which is usualy reading variables from MCU. I have problem with repeat reading instructions. I need every 5 seconds read variables from MCU and show it in HTML page, but with my code it read only once and then nothing. I tryed to use timeout, but it doesnt work.
Thank you for advice.
<body BGCOLOR=white>
<object name="pcm" width="0" height="0"
classid="clsid:48A185F1-FFDB-11D3-80E3-00C04F176153"></object>
<script type="text/vbscript">
Dim Teplota(5)
Dim Vlhkost(5)
Dim Sensor(5)
Dim Signal(5)
Dim flag
Function Update()
flag = pcm.ReadVariable("Sensors_data[1].temperature", Teplota(1), tValue, bsRetMsg)
flag = pcm.ReadVariable("Sensors_data[1].humidity", Vlhkost(1), tValue, bsRetMsg)
flag = pcm.ReadVariable("Sensors_data[2].temperature", Teplota(2), tValue, bsRetMsg)
flag = pcm.ReadVariable("Sensors_data[2].humidity", Vlhkost(2), tValue, bsRetMsg)
flag = pcm.ReadVariable("Sensors_data[3].temperature", Teplota(3), tValue, bsRetMsg)
flag = pcm.ReadVariable("Sensors_data[3].humidity", Vlhkost(3), tValue, bsRetMsg)
flag = pcm.ReadVariable("Sensors_data[4].temperature", Teplota(4), tValue, bsRetMsg)
flag = pcm.ReadVariable("Sensors_data[4].humidity", Vlhkost(4), tValue, bsRetMsg)
flag = pcm.ReadVariable("Sensors_data[5].temperature", Teplota(5), tValue, bsRetMsg)
flag = pcm.ReadVariable("Sensors_data[5].humidity", Vlhkost(5), tValue, bsRetMsg)
For i=1 To 5
    Vlhkost(i)=Vlhkost(i)/10
    Teplota(i)=Teplota(i)/10
    document.write("<TR>")
    document.write("<TD WIDTH=200>")
    document.write("<H2>Jednotka ")
    document.write(i)
    document.write("</H2></TD>")
    document.write("<TD WIDTH=200 ALIGN=RIGHT><H2 TEXT=red><FONT COLOR=red>")
    document.write(Teplota(i))
    document.write("°C")
    document.write("</FONT></H1></TD>")
    document.write("<TD ALIGN=RIGHT WIDTH=200><H2><FONT COLOR=blue>")
    document.write(Vlhkost(i))
    document.write(" %")
    document.write("</FONT></H2></TD>")
    document.write("<TD ALIGN=RIGHT WIDTH=300><H2>")
Next
end function
SetTimeout "Update()", 5000
</script>
</body>
</html>
1,452件の閲覧回数
Inzunzo
I use this and works OK. Hope it helps.
Sub ReadSettings
    Dim succ,v,tv,retMsg
    succ = pcm.ReadVariable("u8_Batt",v,tv,retMsg)
    If succ then
        anyVariableYouWant = tv
        anyErrorDisplayYouWant = "No Errors!"
    else
        anyErrorDisplayYouWant = retMsg
    End If
    setTimeout "ReadSettings",5000
End Sub
</script>
    </head>
        <body>
        <object classid="clsid:48A185F1-FFDB-11D3-80E3-00C04F176153"
                id=MCB_PC_Master_Services1
                name="pcm" width="0" height="0">
        </object>
        </body>
    </html>
Good Luck
