read a programed target, save program and download program to a new target
2,621 次查看
Valentinjbv
hello,
i have a 56f8014 which has a program that I need to copy and save, and then save or download the program in another new and empty 56F8014, which would be the steps that I should take to copy the program without deleting or damage it and that it works exactly the same in the new 56F8014.
I am new to this, I would appreciate your help
标记 (1)
2,587 次查看
xiangjun_rong
Hi, valentin,
Do you have source code? If you do not have, we do not support the utilization generally that you copy the binary code and data from flash and write to another DSC, because it may infringe the other company IP.
Anyway, if you developed the code but lost the source code, you can use flash programmer tools to read the binary code.
https://www.nxp.com/webapp/sps/download/license.jsp?colCode=56F8XXXFP
XiangJun Rong
2,576 次查看
Valentinjbv
yes, I am the developer and I lost the source code, but I really don't understand how to use flash programmer tools to read the binary code. can you explain the procedure step by step please?
