qg8 sci at 115200 baud?
4,359 次查看
jim
Is it possible to configure the SCI in the 9S08QG8 to run at 115200 baud using the internal clock?
1,724 次查看
jim
Thanks!
Jim
1,724 次查看
Wings
Sure is. There's a QG8 right behind me sending/receiving data at that rate right now.
You have to calibrate the ICS for 36KHz to get a BUSCLK of 9.216MHz, then set the SCI baud rate register to 5.
1,724 次查看
hek
A very related question to the question above.
Is it possible to configure QE128 (guess it has the same ICS as qg8) to 230400 baud with ICS? Im having a hard time figuring out all the dividers and ICRs etc. for that to be possible...
Best regards Henrik
