push and pop CCR register on stack
3,309 次查看
grzegorzK
I use MC9S08DZ60. I would like to get functionality to push and pop CCR register on/from stack.
Something similar as quoted macros below (from PE) but CCR saved on stacked variable, not global variable as in example from PE
#define SaveStatusReg()       { asm PSHA; asm TPA; asm SEI; asm STA CCR_reg; asm PULA; }
#define RestoreStatusReg()   { asm PSHA; asm LDA CCR_reg; asm TAP; asm PULA; }
where CCR_reg is global variable, I would like to use auto variable located on stack,
e.g:
#define SaveStatusReg()       volatile byte CCR_stack;  asm PSHA; asm TPA; asm SEI; asm XXX CCR_stack; asm PULA;
Could someone help me?
Best Regards
/Greg
3,020 次查看
kef2
Senior Contributor V
#define SaveStatusReg()       char  CCR_stack; asm PSHA; asm TPA; asm SEI; asm STA CCR_reg; asm PULA;
Should work, provided SaveStatusReg() in { } block comes immediately after variables. Like
void foo()
int a;
char b;
    // only variables here
    SaveStatusReg();
or
void foo()
int a;
   a++;
   a--;
   char inner_block_vars;
       SaveStatusReg();
        RestoreStatusReg();
4 回复数
3,021 次查看
kef2
void foo()
int a;
char b;
    SaveStatusReg();
or
void foo()
int a;
   a++;
   a--;
       SaveStatusReg();
        RestoreStatusReg();
3,020 次查看
grzegorzK
Yes, works (if somne want use it, be cerfull with typo in name of auto variable)
Thank You.
3,019 次查看
tonyp
Senior Contributor II
ASM8 uses the PSHCC and PULCC internal macros which correspond to this:
[from ASM8 manual http://www.aspisys.com/asm8.pdf]:
PSHCC (PUSH CCR)
PSHA
PSHA
TPA
STA 2,SP
TAP
PULA
PULCC (PULL CCR)
PSHA
LDA 2,SP
TAP
PULA
AIS #1
PSHCC is careful to not change the CCR bits on push.
Hope this helps.
3,020 次查看
grzegorzK
hi
thank you for your replay.
I do not understand what means "internal", internal of what? I should mention that I use CW10.6 envornoment for build target. I am looking macro for use in C module as in Processor Expert example.
/GReg
