If you check my second post here it says to use the MultilinkCyclonePro menu.
If you haven't got this menu go to Component|Set Connection.
Select HCS08 and Multilink here.
Now you should have the menu and can continue.
Regards David
Message Edited by peg on 2006-06-12 01:17 PM
