passing command line arguments in Code warrior
1,845 次查看
namit
     i need to know how to pass command line arguments in code warrior.
1,188 次查看
CrasyCat
Specialist III
Hello
What are you trying to achieve here?
Do you want to use argv and argc in your HC08 main function?
Why do you need that? This is absolutely not standard in embedded programming.
CrasyCat
