mc68908gr16 eeprom
mc68908gr16 eeprom
901件の閲覧回数
petermarshall
We have an issue with programming the EEPROM in this  device while the device it is used in is being built.
The PCA gets burned in after firmware has been loaded, then sometimes it is found not to be able to copy to its EEPROM, the operation returns 'VERIFY FAILED'.
Has anyone else seen this issue?
Burn-in is 72 hours at 125C
Thanks.
0 返答(返信)
