i want to know how to develope the application in beestack mc13213
paramasivan
hi,
i am going to use PAN4555 freescale zigbee beestack in my aspplication.i had downloaded BEEKIT & CODEWARRIOR6.2 softwares from freescale site.
when i am  using the BEEKIT software i selected  star network templates and give the pan & mac ids and finally export that project.If i am importing the .XML file in the codewarrior it shows lot of supporting c,header & library files for initilize the beestack.Now what my doubt means, from where i will start my code for simply transmit the data FROM CORDINATOR and receive the same data in the END DEVICE.
1)What are the steps i will do in the software??
2)Already beestacks are all initalzed in that code.Any need to check all that codes??it has more than 20 files for support.
i want a simple example code for transmitting and receiving data htrough STAR or MESH network in my first step at beestack zigbee development..
kindly anyone give a sugesstion how start the applications in beestack......
regards,
S.PARAMASIVAN
Mads
This might seem like a standard answer, but I would read the documentation bundled with the Beekit.
1. There is a Beestack 2007 Documentation overview document that tells you what the different documents contain
2. The ZAUG (ZigBee Application Users Guide) tell you how to use the example/demo applications.
    I can only recommend that you try out the step by step instructions in order to learn a bit more about ZigBee
3. then finally the BeeStack Application Developers Users guide contains step by step instructions on how to create a small simple ZigBee application.
read the documentation and try out the instructions.
If this is not enough the consider acquiring Drew Gislason's book on ZigBee - it uses BeeStack for all its examples.
BR,
Mads
