how to trim internal reference clock to obtain 16Mhz in S08?
1,339件の閲覧回数
partner_s_shela
How to trim internal reference clock to obtain 16MHz in S08?
2 返答(返信)
1,166件の閲覧回数
w_tension
Trim value can be set to get 31.25 kHz when using P&E Micro programmer.
Select intern reference as FLL clock source. You will get 16MHz core speed.
But intern clock is easily influenced by temperature.
1,167件の閲覧回数
vicentegomez
please check the AN3499
depending the S08 family that you are using, is the clock configuration that you need to set.
