best way to initialize a TPM in PWM mode.
4,090 次查看
TurboBob
I am using the TPM modules with the Processor Expert beans.  They work great, but when the cpu initializes, the output pin sends at least one pulse.  There is a pull-down on the output to be sure its low during initialization.
I have the PWM mode 'disabled' and initialized to 'low' in the bean.  Is there something I am missing?
Bob
标签 (1)
5 回复数
2,429 次查看
ProcessorExpert
Senior Contributor III
We need more information in order to reproduce a problem. Could you please provide us a project demonstrating this problem or send us settings of PWM bean?
What version of Code Warrior and Processor Expert are you using?
Which derivative are you using?
best regards
Vojtech Filip
Processor Expert Support Team
UNIS
2,429 次查看
TurboBob
can you give me an email address to send the file?
Its a JM60
Its codewarrior 6.2,  I will check the PE version and post it.
bob
2,429 次查看
TurboBob
PE version is 3.03
Bean init is attached
2,429 次查看
ProcessorExpert
I have not reproduced such behaviour therefore could you please send a project demonstrating the problem to: support(at)processorexpert.com
best regards
Vojtech Filip
UNIS
2,429 次查看
TurboBob
sent the project to you
thanks
