asm method
asm method
2,152件の閲覧回数
DavidoBG
I would like doing a jump to 0xE000 adress in my main function but i have an compilator error
asm{
      JMP.W #E000H
Error : Factor expected.
I am looking for solution with specific factor but i cannot find.
thanks
David
1,433件の閲覧回数
DavidoBG
OK It is good thanks
1,433件の閲覧回数
Ake
I am not sure of which C-compiler you are using, but to use the CW compiler, you should write
  asm{
      JMP  0xE000
and that would be OK for HC08, 9S08, 9RS08 and F51 MCUs.
Ake
