ZSTAR3 (HCS08): Is it possible to change a sensor's index?
monpat
Hello everybody
I work with several zstar3 sensors and I would like to change their IDs (index). Is there a command for this?
Thanks!
monpat
Gargy
 yoe there is command to change sensors ID. There is two possibilities how to change this ID:
1. If you a re using the zstarlib.dll library, the situation is easiest - It must be called (when sesor is connected) theSensor.IndexSet(newIndex) method.
2. If you are communicated directly over serial/USB protocol - It must be sends command 'F'and new index to active sensor.
Have a nice day
drfordo
But how could i change it .My sensor dosn't active .although my usb receiver connect to zstar3 and active .I mean the programm found  usb receiver but sensor doesn't work. I guss this proplem happend becaus i try to change simple rate data(form 30HZ to 60HZ) before i change index .
please help me to make my sensor work again
this is my email: mans_78@yahoo.com
