Where is the StackSize setting in eclipse version
Geoff_L
I'm using the codewarrior eclipse version (10) for MC9S08AC48.  I can't seem to find the stack size setting in the IDE - only in the .prm file, which will be overwritten eventually by the PE Processor expert tools.   Can someone point me to the correct menu?
ProcessorExpert
Senior Contributor III
property that influences generation of stack size into prm (HCS08) or lcf (CFV1-4, Kinetis) is placed on the same place as in Codewarrior Classic in the "Build options" tab in CPU component. For more details please check enclosed screen-shot.
best regards
Vojtech Filip
Processor Expert Support Team
