Unknown Base plugin Nub error
3,645 次查看
tcherno
hello,
I have a project in Code Warrior 10.6.4 IDE developed for MC9S08QE128 MCU.
I am using PE micro Multilink FX as a debugger and programmer.
until a week ago I was able to debug and burn the code. to the flash of the MCU with no problem.
now when i try to debug or burn the code i get the error "Unknown Base Plugin Nub error".
with the PROGHCS08 - Flash Programmer Software from PE micro i have no problem burning the code on the board with the same debugger.
when checking the signal of the BDM, i can see that the PC tried to initiate connection with the MCU.
have anyone faced this problem and can help me?
thank you,
omer
3,559 次查看
pawantanwar
Restart CodeWarrior and reconnect the Multilink FX. Update P&E drivers for CodeWarrior and Multilink FX. Reset debug settings (Project > Properties > Debug/Launch Settings) and clear the workspace cache by deleting the .metadata folder.
thanks and regards
pawantanwar
https://www.multispanindia.com
3,614 次查看
Pablo_Ramos
Hi @tcherno,
I noticed that you already made a similar question on other community post. There is some activity in said post so please follow up there. I’m adding a link here for reference of other community users that may find it helpful.
Unknown Base Plugin Nub error - NXP Community
